link tif image to revit
3 ANTWORTEN 3
Nachricht 1 von 4
qchenTPPXV
164 Aufrufe, 3 Antworten
Greeting,
I would like to link a tif image into Revit and it shows the error message as below:
It's a large size of drone image and not sure if it is the problem.
3 ANTWORTEN 3
Nachricht 2 von 4
SteveKStafford
als Antwort auf: qchenTPPXV
Try editing the image file in image processing software and create a smaller file size/version or alternate file type like JPG to see which will work.
Steve Stafford
Nachricht 3 von 4
Save is as a PDF then link or import the PDF.
Nachricht 4 von 4
handjonathan
Hi @qchenTPPXV
Thanks a lot for posting your question to the forums!   Has the solution suggested by @SteveKStafford @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
