Link Revit Dialogue Does Not Display
6 ANTWORTEN 6
Nachricht 1 von 7
anthonymctigue
520 Aufrufe, 6 Antworten
I have a bit of an unusual one.  On the Insert Tab, when I click on Link Revit, the dialogue box that allows me to browse and link in a Revit file does not display.  The other icons grey out and the main Revit interface is inactive until I press escape so Revit seems to think that the dialogue has displayed.  I get similar behaviour when I try to launch the Link Revit dialogue using Manage Link (see attached screenshots).  I have also tried the various Windows 10 commands for cascade and stack windows but I cannot see it anywhere.  Has anyone ever encountered this and how does one go about fixing it?
Main Revit Interface before pressing Link Revit
 Main Revit Interface after pressing Link Revit
Tags (1)
6 ANTWORTEN 6
Nachricht 2 von 7
anthonymctigue
als Antwort auf: anthonymctigue
I forgot to add, the Link IFC, Link CAD, DWF Markup, Decal, and Point Cloud dialogues all display correctly.
Nachricht 3 von 7
Alfredo_Medina
Maybe the dialog box is opening in a second monitor.
Nachricht 4 von 7
anthonymctigue
als Antwort auf: Alfredo_Medina
Alfredo,
thanks for your suggestion however I have checked this and it is not the case.  I also tried the various Windows 10 tile/cascade tools but still could not see where it is hiding.  I also tried disconnecting all monitors (I normally use 3) except one but still could not see it.
Anthony
Nachricht 5 von 7
have you find you solution? i also faced the same problem.
Nachricht 6 von 7
anthonymctigue
als Antwort auf: Anonymous
Nazrul,
Apologies for the delay in response.  I have been overseas for the last few weeks and just getting caught up on everything that has happened during that time.  Unfortunately I have not had any luck with this and it certainly seems to be an odd one.
Anthony
Nachricht 7 von 7
Hi anthony, i have found the solution for this. but it's quite ridiculous. the dialog box appear on my colleague second screen. it solve.
my case is i work with my colleague screen. then when he came back i continue with my 2nd screen. then the dialog box not appear in my 2nd screen. suddently when i just try to connect back to my colleague 2nd screen its back to normal.
*you need to use the same screen where you transfer the dialog box.
thanks.
nazrul
