Link CAD only to Auto options, only Internal Origin
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
611 Aufrufe, 6 Antworten
Hi!
this is the first time I post something here, I am kind of despairing...
I thought I had figured out the whole coordinates thing, but apparently not.
In any case, I will start with the most recent issue, which is that when I try to link a CAD now, I only get the followin options:
What could be the reason for that?
Thank you all in advance!
Beschriftungen (2)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Select a DWG and see if you get more options. What view are you Linking into?
Nachricht 3 von 7
Oh, I see what's going on. You are accessing that dialog box through Manage Links. Use Link CAD on the Insert Tab.
Nachricht 4 von 7
als Antwort auf: barthbradley
Thanks for the quick replies!!
Oh going via Insert worked for getting also the manual options!
However, I still get the option Auto-Origin to Internal Origin, so I can't link to my Project Base Point.
I was linking on a plan view. But it didn't change in a 3D view...
Nachricht 5 von 7
Hello again! I have accepted the reply suggesting one goes via Insert as a solution, as it provided med with more insert options. And want to thank you again @barthbradley for the quick and to the point help! :leicht_lächelndes_Gesicht:
I am however still wondering why I get "Auto-Origin to Internal Origin" option.. Which I suspect will mean that as I continue working on the project, it will be hard to link other models (from other consultants) accordning to Project Base Point. :verwirrtes_Gesicht:
Nachricht 6 von 7
Project Basepoint option is only available when you link Revit, not CAD.
Nachricht 7 von 7
als Antwort auf: ToanDN
Right!!! Thanks!!
