Hello all,
After purged the useless elements from the autocad file I linked it in Revit. I see that some blocks are corrupted (image - 2) in revit but some others not (image - 1 ) . I tried to explode the blocks in the editor block but the result is the same.
Do you have any idea how can I fix it ??
Thank you in advance!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
an you post the DWG you are trying to link into revit?
Howard Munsell
Thank you for your answer,
I tried this approach :
'If you do not have access to AutoCAD, an alternative is to start a new Revit project file, import the drawing, and fully explode it. Then export that view back to AutoCAD and import it into your Revit project.'
But when I imported again the 'new' autocad in Revit I had the same problem. So I linked directly the Revit file (with the imported and exploded .dwg)
