Link Area parameters to spreadsheet
3 ANTWORTEN 3
Nachricht 1 von 4
437 Aufrufe, 3 Antworten
I am looking to do some number crunching a bit beyond what Revit's scheduling functions are capable of. I have a spreadsheet set up for analysis of building areas which we are using to submit for a building permit. I know Revit can extract areas from Area or Room Boundaries to a schedule and then add them up to create a total. The problem is I need to create a matrix which shows all of the areas which contribute to the overall building area, but I need to separate them into columns of areas which the city counts toward GFA and areas which it doesn't.
Ideally I'm trying to find a method of linking a specific area value parameter, say from an Area Boundary or a Filled Region, to a cell (could be in excel or in a Revit schedule, I don't really care) which I can then arrange in an editable matrix to create the values I need to inform our submission. I'm a bit of a novice so forgive me in advance if I need extra-detailed instructions.
I've attached a sample image of the matrix I'm building to help illustrate.1635 Areas.jpg
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Looks like it can be done easily in Revit by placing 2 schedules next to each other or am I missing something?
Nachricht 3 von 4
als Antwort auf: ToanDN
I think that could work for this particular stage, but I may have made the example overly simplistic. At a further stage I will need to be able to add Columns 1&2 and Columns 3&4 for building code analysis. I will also need to prepare a matrix with site area information which will require adding several yard areas and multiplying the yard areas by certain by-law mandated percentages to ensure we are achieving soft landscaping requirements.
I'm finding the schedule function is fine for extracting a series of single values and adding those values to get a single total. But ultimately I need a tool which can combine certain totals and feed them through the city's and the building codes required formulas. I'm not expecting Revit to provide this level of functionality as a standard but if there's a way to link the values to a spreadsheet program (through a plug-in, maybe?), that would help take my BIM work to the next level.
Nachricht 4 von 4
