Hey,
My linework is turning light gray but elevation lines, text and tags are all still black. When it's in the revit model it shows it's black but when printing it to PDF if changes. Any one have any idea how to fix this?
Cheers,
Dylan.
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Anonymous
I see that you are visiting as a new member! Thanks for posting on the community forum![]()
Which PDF printer are you using?
Is your Printer dialog box set to print raster or vector?
Try with different PDF writers*
Similar post HERE
Please see HERE and HERE for Best Practices: Printing and lets us know if you have additional questions.
*I have provided a link to an application or add-in that MIGHT provide the extra functionality for which you are looking. Please note, however, this is not an Autodesk product or endorsement. You should take all precautions whenever you elect to download/install/utilize any application and do so at your own risk.
*Please review the developer’s documentation and disclaimers before proceeding to utilize their product(s).
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
