Linework - Invisible lines
fachp_29
Message 1 of 10
fachp_29
Hola, hasta hace poco no he tenido problema uniendo geometría y ocultando la línea entre ambos elementos. Pero ahora cuando selecciono y las quiero ocultar en lugar de ser invisibles se tornan grises. Revisé en manage>>line styles y no tengo forma de configurar el color o visibilidad de esa línea.
Lo siguiente es que si selecciono otra línea que no sea de unión, si desaparece. Help 😞
Accepted solutions (3)
Replies (9)
Message 2 of 10
hmunsell
if you select the "Grey" line, can you set it to Invisible? If so, does the grey line disappear?
Howard Munsell
Message 3 of 10
fachp_29
I cannot select it, unless I use another type of line in "linework". If I choose overhead, it goes overhead, the problem is the invisible line which goes gray 😕
Message 4 of 10
hmunsell
interesting.... I haven't seen that happen before. i though maybe there was a line under the line you set to invisible. i see that happen with Structural slab edges and footing all the time.
would you be able to upload an example file where this is happening?
Howard Munsell
Message 5 of 10
fachp_29
I´m sending a model (2023), I´ve just created it, added two walls and floor, tried to make invisible te joint, but as you´ll see, its not working.
Message 6 of 10
ralphdenhaan
You can try to turn off the wall common edges:
Or another workaround is to create a White Line Style and use Linework.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Message 7 of 10
Use the same Material for the Wall and Floor.
Message 8 of 10
hmunsell
@barthbradley  REALLY.... 😂   I was initially thinking that, but they were both set to "By Category".   but your right... when I looked at the object styles, they had Defaults applied to them.  remove the default materials in the object styles and the line goes away.
Howard Munsell
Message 9 of 10
fachp_29
thanks you, I changed<by category> for any material and it worked. Also is astute to create a new line. Thank you all. Greetings.
Message 10 of 10
Isn't that what I suggested?
