Linework in view template is grey/halftone
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
cbt990
315 Aufrufe, 3 Antworten
Everything in a given workset has grey cut and projection lines/patterns. However, the view template doesn't seem to have any filters applied which impact the workset. There are no overrides and the project has no phase functionality.
Also, manually overriding to show these cut lines as black or another color doesn't work - no change appears on the screen.
Hopefully these details can give some clues about what else to troubleshoot.
Also, when I use the OTB section template, these elements still appear grey. I cant imagine why they aren't showing up normally in the OTB template.
Charlie
Revit is amazing
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: cbt990
I don't believe there is no Override acting on the View.   It there's nothing overridden, then that's how it looks based on the Project's Object Styles.  Can you verify? Create a brand new View just like that one. Any difference between the two?
FWIW:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-D...
Nachricht 3 von 4
Wait a minute. Workset?  Is Gray Inactive Worksets checked?
Nachricht 4 von 4
cbt990
als Antwort auf: barthbradley
We found the Halftone override, missed that before. Sorry, and thanks!
Revit is amazing
