I have some issues with lineweights in my model:
-The line weights of the linked file in my host model are not correct, for instance the host model objects (in sections) are correctly drawn (line weight 6 is indeed 6) but the objects of the linked file are much thicker (line weight 6 is drawn as 9). Looks like the line weight is double that of the host model objects.
No override will work: tried filters, tried overriding custom linked file override, nothing works.
I heard that its a bug but has anyone have more information?
Gelöst! Gehe zur Lösung
Gelöst von hve-architecten. Gehe zur Lösung
Well found out what the problem is. In the host model we have different columns for line weights (1:5/10/20/50/100).
The linked file did not have the line weight column of 1:5!
So the problem was in our 1:5 view templates and after adding our 1:5 column to the linked file i get correct line weights in our view template.
