Hey everyone, Revit noob here
So what I want to know is if there is a way to justify lineweights to the interior of a wall in a section. So that when there is a change in lineweights, for instance a coarse filled wall section to a door jamb, there is no kickout from the change of lineweight. In the revit a section everything looks great with crisp interior and exterior face alignment, but in the pdf, I see noticeable kickouts from the change of lineweights.
Is there a way to fix this other than putting every lineweight to 1?
In the attached PDF I'm concerned about how the dimension line does not align with the face of the ceiling or floor because of the thickness of the lineweight. It's causing some concern with the people who use these dimensions for their work. They're not sure which line to trust.
