I created a simple window family, used an extrusion for the glass, and set the extrusion material to 'glass'. I want to reduce the glass extrusion lineweight, but changing the 'cut' thickness of 'Glass' in Object Styles has no effect. What am I doing incorrectly?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Is view Wireframe ??? Did you Load family into project and check?
Sorry if yoy already posted images,,, I'm reading/replying via email, images don't display
You assigned material as Glass, not the subcategory...Scroll a little bit more downwards and select from the drop down Glass Subcategory (See GiF below)
Sorry to bother, but the changes don;t seem to carry over into the project??
I changed Windows > Glass cut lines to '2' in Object Styles - no effect.
