LINES PREPARED FOR EXPORT TO DIFFERENT LEVELS IN AUTOCAD
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
692 Aufrufe, 1 Antwort
Hi All,
For a drawing that is to be CNC milled, we'd like to develop drawings with line styles set to export so they will appear in dwg on different layers.
This way the same drawing can be used for different cuts by turning on and off layers. Can't figure out how to set up the export. All line types always appear on same layer in acad.
Amy
1 ANTWORT 1
Nachricht 2 von 2
Sahay_R
als Antwort auf: Anonymous
Identify your linestyles and set them to go on whichever layer you need them to. The same applies to any object categories. If you scroll further down from where my screenshot was taken, you will see a whole bunch of Revit linestyles going on to the same ACAD layer.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
