Lines overlapping - pdf
7 ANTWORTEN 7
Nachricht 1 von 8
borcheva
1060 Aufrufe, 7 Antworten
Hello!
Is there any way to avoid the overlapping lines (for example - walls in black and rot) in pdfs?
In Revit it looks good, exactly what I want.
I've also tried different pdf printers, that didn't solve the thing.
Thank you in advance!
Anastasia.
Beschriftungen (1)
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: borcheva
Can you elaborate - the only difference that I can see is that the second image has thinner lines.  Try press TL (thin lines) in Revit to show the actual line thickness.
Nachricht 3 von 8
borcheva
als Antwort auf: Anonymous
thanks for the answer.
In the screenshot it's already with the actual thickness.
I've attached here the pdf file - so as you can see, there's the overlapping - the red edge of the thin wall is above the black line of the load-bearing wall.
I wish here but the black line above the red line - so I see it in Revit.
Nachricht 4 von 8
Can you confirm the scale of the drawing and the thickness of the thin wall?
It might help to reduce the lineweight of the common edges.
Nachricht 5 von 8
borcheva
I've tried to make the black lines thicker, so it looks on the paper a little better.
In pdf you still can see these red overlapped lines, that may not be as dramatic anymore and I can neglect (but dont want :)) this perfectionism.
The attached pdf is in the scale (1:50 metric), black (load-bearing) lines are 0,4 mm and red (not load-nearing) are 0,05 mm.
The only wasteful way to get rid of these overlapped lines, as I see, is to make these edges invisible with the Linework Tool...
Nachricht 6 von 8
Hard to tell what you are referring to, but if I were to zoom in tightly on any overlapping linework in one of our PDFs, I would be disappointed too.  It is an issue at "normal" scale?  Can you discern "the forest for the trees"?
Nachricht 7 von 8
RDAOU
The black line ... is that the boundary of the grey filled region? If yes, then there could be several ways to resolve that over printing... example:
- you could try setting it as masking
- or you could overlay the region over the plan (2 separate views) on the sheet instead of in the same view
Nachricht 8 von 8
manuel_coletto
Hi.. i can undertand because im facing the same behavier.  Have a look here. https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Lines-intersecting...
