Lines on Void Family when placed on Model
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
1534 Aufrufe, 5 Antworten
Hi, can someone tell what I can do to fix this? I've spent hours trying to find a solution. Thank you
5 ANTWORTEN 5
Nachricht 2 von 6
MostafaElashmawy
als Antwort auf: Anonymous
Select the Void family>>Edit Family>> Select the lines then click on "Convert Lines".
This will convert the model lines into 2D drafting line that don't show in 3D.Annotation 2019-12-29 100709.png
Mostafa Elashmawy
Nachricht 3 von 6
Can you identify the line types for us?
You can always post the file as well.
Nachricht 4 von 6
RDAOU
Using Convert lines simply converts symbolic lines to model lines and model lines to symbolic... and that wont make them invisible! Symbolic line would still be visible in other views!!!!
If its a void family, no lines should be used in it … UNLESS:
1. You either added them by mistake and you do not really need/want them in your model...in such case Edit Family and delete them
2. OR you are annotating it with symbolic or model lines for some purpose which you want to preserve. In this case, use symbolic lines instead of model lines, control their visibility based on detail level, add a visibility parameter and/or add them to a subcategory which you can switch on or off in the project
3. OR they are some profile or Construction lines required in the family (ex: projection lines/trim lines...etc) in such case assign them to s subcategory which you can control in Visibility Graphics
Nachricht 5 von 6
als Antwort auf: RDAOU
It ended up being an issue of not adding another ref plane on the extrusion but thank you for your answer
Nachricht 6 von 6
Looks like the void is not deep enough to cut through the entire host.
