I am trying to use model lines in 3D view and they appear to be created but I cannot see them, and I get the warning that the element i have created is not visible in this view, check view parameters and visibility settings.
I dont get it, I thought model lines ALWAYS show up in 3D view, and I also cannot figure out anywhere there could be a setting to change this.
PLEASE HELP!!1
The problem is when you are drawing a model line (LI) in 3d, pick a new plane to draw the line. Maybe the current plane is at a level that you cannot see the line. SET the plane using PICK A PLANE and pick on a surface that is visible in 3D like the top of a cabinet, whatever. Once the new plane is set, draw the model line (LI). Don't forget to delete it once you're done
