Lines messed up when importing DWG
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
jayme.neto
4605 Aufrufe, 10 Antworten
Hello guys.
I'm trying to import a DWG to Revit but it is coming with the lines messed up. Here some images to illustrate the problem.
Two information that may be useful (I don't know)
- The original DWG was exported from a Revit model
- The DWG drawing is entirely made of blocks
Does anyone know whats is going on?
Tags (2)
Beschriftungen (1)
10 ANTWORTEN 10
Nachricht 2 von 11
syman2000
als Antwort auf: jayme.neto
Move the DWG to origin 0,0. If the drawing is 20KM away, your line will display jagged.
Nachricht 3 von 11
I'll bet the DWG is located far, far away from the Internal Origin.
Nachricht 4 von 11
jayme.neto
als Antwort auf: barthbradley
Tks for the help!
Unfortunately, that's not the case. The DWG is near the origin and the building has less than 100 meters.
Nachricht 5 von 11
syman2000
upload the CAD file.
Nachricht 6 von 11
I was talking about Revit's Internal Origin - not the WCS Origin in the DWG.
...a.k.a. the Project Base Point Startup Location.
Nachricht 7 von 11
ennujozlagam
you can try this, in autocad try the command overkill, flatten, ucs > world > plan and viewres > y> 20000 and purge and see if helps. thanks
Nachricht 8 von 11
vancikv
In my experience, this happens for one of two reasons:
1) The jagged lines come from a dwg that is indirectly linked, i.e. nested in another dwg which is actually linked in Revit.
2) Blocks - sometimes I just have to explode the blocks, or it won't behave. Not sure why, but I've seen blocks that have an internal origin very far away, even though all the geometry is in the project area, guess that can cause issues.
Nachricht 9 von 11
moraruandrei29
Anyone figured this out? I have the same problem. The drawings are however close to the origin in Revit.
Nachricht 10 von 11
jayme.neto
als Antwort auf: vancikv
I exploded the blocks and this solved my problem. :daumen_hoch:
Tks
Nachricht 11 von 11
I tried all this,methods, it seems that overkill is best solution... Thanks
