Lines messed up when importing DWG
10 REPLIES 10
Message 1 of 11
jayme.neto
4270 Views, 10 Replies
jayme.neto
Hello guys.
I'm trying to import a DWG to Revit but it is coming with the lines messed up. Here some images to illustrate the problem.
Two information that may be useful (I don't know)
- The original DWG was exported from a Revit model
- The DWG drawing is entirely made of blocks
Does anyone know whats is going on?
Hello guys.
Tags (2)
Labels (1)
10 REPLIES 10
Message 2 of 11
syman2000
in reply to: jayme.neto
syman2000
Move the DWG to origin 0,0. If the drawing is 20KM away, your line will display jagged.
Message 3 of 11
I'll bet the DWG is located far, far away from the Internal Origin.
Message 4 of 11
jayme.neto
in reply to: barthbradley
jayme.neto
Tks for the help!
Unfortunately, that's not the case. The DWG is near the origin and the building has less than 100 meters.
Tks for the help!
Message 5 of 11
syman2000
syman2000
upload the CAD file.
Message 6 of 11
I was talking about Revit's Internal Origin - not the WCS Origin in the DWG.
...a.k.a. the Project Base Point Startup Location.
Message 7 of 11
ennujozlagam
ennujozlagam
you can try this, in autocad try the command overkill, flatten, ucs > world > plan and viewres > y> 20000 and purge and see if helps. thanks
Message 8 of 11
vancikv
vancikv
In my experience, this happens for one of two reasons:
1) The jagged lines come from a dwg that is indirectly linked, i.e. nested in another dwg which is actually linked in Revit.
2) Blocks - sometimes I just have to explode the blocks, or it won't behave. Not sure why, but I've seen blocks that have an internal origin very far away, even though all the geometry is in the project area, guess that can cause issues.
Message 9 of 11
moraruandrei29
moraruandrei29
Anyone figured this out? I have the same problem. The drawings are however close to the origin in Revit.
Message 10 of 11
jayme.neto
in reply to: vancikv
jayme.neto
I exploded the blocks and this solved my problem. 👍
Tks
Tks
Message 11 of 11
nermin_hadziomerovic
I tried all this,methods, it seems that overkill is best solution... Thanks
