Lines in the join of walls
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
mairh_tsek
1293 Aufrufe, 2 Antworten
Hello all,
 Is there any way to disappear these lines between the join of the walls? ( the one walls doesn't overlap the other.)
Thank you!
2 ANTWORTEN 2
Nachricht 2 von 3
cbcarch
als Antwort auf: mairh_tsek
Use Join Geometry.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 3
Sahay_R
Modify tab>>Linework>>Invisible Line
Click on the offending line - it will disappear.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
