I can see center lines and spacing boundaries of piles which are located outside of the exterior wall, but can't see them located under the slab. But the weird thing is I can see them when they are plotted in raster mode. The problem is, I need them to plotted with vector mode.
Dose anyone have a solution?
Hidden lines do not print to PDF as seen on screen in Revit (autodesk.com)
Which PDF driver are you using? Adobe, CutePDF, Acroplot, Bluebeam or Revit PDF? Some PDF driver has line merge setting which allows you to see line overlapping showing up in PDF plot. Some PDF driver don't have these feature.
Thank you for your apply.
I haven't exported them as PDF, put printed on paper. I'm using Adobe PDF, and Revit 2024 by the way.
Thank you for your reply. According to the link that you shared, it seems like the error has been updated from Revit 2023, but I'm using Revit 2024. I'm trying to update my Revit again ![]()
What printer/plotter are you using? Some printer have CAD profile.
