Linear Light Family with parametric angle joinery
Hi Everybody,
I am having a hard time with a linear light family that I created. I made a parametric family which can be edited for width and length etc. as a line-based family. The problem that I am having is that I need the trim to meet at a range of odd angles. I have tried several methods to make an angled void or to make the family itself extend and end at an angle parametrically and have not had any success.
I hope that this question made sense. Any help would be extremely appreciated! I am trying to use this for my thesis which is do in less than two weeks.
Thanks in advance for all your help!
Naomi 🙂
_Vijay
if there is 90 degrees you can use below snips and use joint geometry, or you need a model separate family with respective angle (reference line with angle ).
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
