Line weights
3 ANTWORTEN 3
Nachricht 1 von 4
55chuteT9MXS
209 Aufrufe, 3 Antworten
Line weights
Hello, is there any way to make the line style dropdown permanently open, like a floating window that I could just dock somewhere on the screen.  Not a big deal, but I have a lot of line weights and I would like to be able to just see the whole list and not have to scroll through all the options each time.  I know the line work tool is a good option but still would like to be able to have the whole list show all the time so I could just click on the styles that I use most of the time without having to scroll through all the rest that I don't use as often.  Or maybe, a shortcut key/script that could be assigned to a specific line weight/style. Or maybe a line palette with just 5 line types that is in the toolbar.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: 55chuteT9MXS
Interesting. So you have so many line styles that it is hard to know which is which. What about a different naming convention?
...you could include the convention in your office standards manual and keep a hard copy nearby for quick reference.
Nachricht 3 von 4
55chuteT9MXS
als Antwort auf: barthbradley
that is a good idea, and then the ones that  I use the most are right at the top.  Let me know if you come up with any other ideas.
Thanks!
Nachricht 4 von 4
I named the commonly used line styles so they appear at the top of the list.
