Working in Revit 2020.2.
Here is my dilemma, I am working in a demolition plan with a demolition phase override. I want my projected walls to be a line weight of 2 and my cut walls to be a line weight of 5. I don’t really care what the hatch line weight is as long as it is the same or greater for the cut wall. The projecting hatch is grabbing the line weight from the object style of the wall’s projection line, line weight (which I believe is the intended function). However, the cut hatch line weight is defaulting to line weight 1. How do I adjust the line weight of the hatch of the cut wall? I would like to be able to either control it (to bump it up to line weight 3) or make it at least not thinner than my projected wall hatch’s line weight. I have included a screen cast of this.
Another weird occurrence is that you will notice as I zoom into the cut wall, you can see the thicker line of the surface hatch behind the cut wall hatch, even though there is only one wall here. Why is the wall giving me both a cut and projection hatch (even though the projection hatch is masked)?
