Line weights built into a template
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1771 Aufrufe, 3 Antworten
I need to add different line weights and colors for the different families in a project template. LVLs with a thicker purple outline, I-Joists with a thin red outline, steel beams with a dashed black outline, etc... So far I have accomplished this by right clicking, and overriding the views per family instance in each project I've worked on. Is there a way to add these settings permanently in this template so when I place an LVL or a group of joists, they appear in the colors I need them to be?
I've tinkered with Manage -> Object Styles but I cannot figure out if this is where I need to do this or not.
3 ANTWORTEN 3
Nachricht 2 von 4
cbcarch
als Antwort auf: Anonymous
Yes--Object Styles will globally control the line display for your categories.
-You should create View Templates for your Structural Views with these modified line overrides, then apply the View Templates to your struct. views in the .rte template file.
-Then when starting new projects from the template file, the views will be set up.
-For existing projects, use Transfer Project Standards, and select View Templates to override your project with the template file's view templates.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 4
als Antwort auf: cbcarch
Okay, I did what you said and while it worked, it only sort of worked. ALL of my families are a single color (red - which should just be my joists). I think it is applying to the category instead of on a per family basis.  Is there a way to split it by family instead of category?
Nachricht 4 von 4
You can create subcategories in the families and assign them to different types of members them for different line weight/color/line pattern.
