AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
Line weight tool
5 ANTWORTEN 5
Nachricht 1 von 6
jfjacques
578 Aufrufe, 5 Antworten
Line weight tool
making schematic models, I often need to hide lines using lineweight tool in 3d. ei, when roofs meet walls.
When I duplicate a 3d view these changes go away - can't duplicate a 3d view as dependent. Is there a way to have these changes be duplicated in another  3d view so as not to repeat the process of hiding these lines?
5 ANTWORTEN 5
Nachricht 2 von 6
Avaris.
als Antwort auf: jfjacques
No, but changing your linework is meant to be a very specific override. Is there a reason why you can't fix it in object styles for example?
Nachricht 3 von 6
Nope....there is a Revit Idea somewhere about allowing the overrides to be duplicated though.
Found it... https://forums.autodesk.com/t5/revit-ideas/maintain-linework-tool-overrides-when-duplicating-view-wi...
Thought I had one too, but mine was for families.
Nachricht 4 von 6
SteveKStafford
Often a bit more modelling effort can eliminate the need for line work, like attach, join geometry, cut geometry, modelling the boundary to the correct side...etc.
Steve Stafford
Nachricht 5 von 6
jfjacques
als Antwort auf: Avaris.
how would I fix it object styles?
Nachricht 6 von 6
Avaris.
It does not matter where exactly you change it; view filter is easier when it is something specific.
Do you have a screenshot?
In Foren verƶffentlichen
