Line weight is not showing up in the section view for imported Objects.
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
pe4655i
858 Aufrufe, 10 Antworten
I imported a .obj file into REVIT 2024 through the import CAD option in the Insert menu. The imported object comes into Revit as a generic model and can be cut by the section box and in a section. However, the section cut line weight of the object does not show up in the section view.
I would agree that this is a problem with the imported obj file; however, the line weights of the object show up in the plan view.
I have attached screenshots of the plan view showing the line weight of the object in the plan view and the screenshot of the section view, which does not show the line weight of the cut object. I have also attached the Revit file.
Please bear in mind that I have also tried changing the visibility graphics of the line weights for the object.
I would be grateful if anyone could help with this problem,
Thanks in Advance.
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: pe4655i
...bumped.
I misread. Overrides don't affect Cut Line Weight of this object.
Nachricht 3 von 11
What happens if you import the obj file into a Generic Model Family and then load that Family into Project?
Nachricht 4 von 11
Like this?
Nachricht 5 von 11
pe4655i
als Antwort auf: barthbradley
I tried, but I still got the same result.
Nachricht 6 von 11
pe4655i
als Antwort auf: ToanDN
Exactly like this
Nachricht 7 von 11
pe4655i
Please tell me how did you get that result?
Nachricht 8 von 11
Just export the model in Revit to DWG and link it back in an in place model family.  Then you can override cut line weight.
Nachricht 9 von 11
pe4655i
Thank you very much; this works very well, especially for a single imported model. It doesn't work for multi-object import. How would I navigate making this work on a multiobject import, as shown in the Revit file attached?
Nachricht 10 von 11
Which program created the OBJ files?
Nachricht 11 von 11
pe4655i
Created in Blender 3D.
