I need help with my Revit(2016) model. The original scale was 1:100. I drew the model at was 1:100 in all views but now I am switching the view scales to fit on a page. When I switched to 1/64"= 1'-0" the view shrunk on my page but all the lines in the view are thick and annotation is huge. I know from what I read online, that annotation is supposed to get larger and I have to manually change it somehow but I have no idea how to change the line weights. Could you explain to me why the lines are so thick? What settings should I change in Revit so that every thing looks proportional in a 1/64"= 1'-0" view?
Go to Manage > Additional Settings > Line Weights. Add 1/64" scale and adjust the line weights for that column.
I doubt seriously that you need to change your line weights, unless someone in the office is pranking you. I would be more inclined to think this is just an accidental view setting you made. Do new views created - and other view scales - display the same way?
Thanks for all the replies. Yes, I tried to change the line weights last night but I started thinking that I messed up a setting so thought I would ask for other ideas first. I believe the elevations are fine its just the plans that look really thick. The lines get thicker and thicker as the scale gets smaller and smaller. At 1/64" = 1'-0" the walls look solid black because the lines of the walls are so thick. How would I change the view settings barthbradley?
1/64"!? What are you viewing? Also, if you messed around with the line weights and changed them last night - change them back to their default OOTB settings. I have never-ever had a need to change these in all the years I've been using Revit.
Thank you. I don't think I would have figured out that scale was not necessary for portfolios unless I had this conversation! Thanks again!
