Line type .
4 ANTWORTEN 4
Nachricht 1 von 5
Darwin33
281 Aufrufe, 4 Antworten
Line type .
In our office are working with a model that came from othe office. We are experience issues when plotting and line with and colour. In the attached picture you can see that the concrete walls (black line) shows one of their lines behind the drywalls (grey line). This is very annoying. Could someone please indentify what is causing this issue and suggest an easy solution.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Darwin33
Replace halftones with thin lines?
Vector or Raster?
Nachricht 3 von 5
Darwin33
als Antwort auf: barthbradley
Yes this way works, but it needs time to go step by step. Do you have a clue why is this happening?
Nachricht 4 von 5
Darwin33
Yes drawing a new line it solve the problem. But my question is why this is happening. Apparently solid line had to bwe drawn over halftones lines. So what is wrong in this model?
Nachricht 5 von 5
No.  For model elements, Revit always print halftoned lines over full-toned lines.  If you want otherwise then you need to use Linework tool to override the full-toned lines to give it the priority.
