Line Tool - Continuos Line From Straight To Curved
3 ANTWORTEN 3
Nachricht 1 von 4
omorah
468 Aufrufe, 3 Antworten
Hello folks, can I draw a "Polyline" in Revit? That is, say I draw a rectangle with a line or the Rectangle button, if I can move this drawn rectangle just by picking one of it's sides.
Also, Can I draw a Straight line from point A to point B, then continue the 'Chain' line by changing to, say, a Spline, then back to a Straight line, then again, a Spline, then close? (Just like in AutoCAD).
3 ANTWORTEN 3
Nachricht 2 von 4
RobDraw
als Antwort auf: omorah
Nope.
Rob
Nachricht 3 von 4
Karol_Piroska
Sure you can. Hover over one of the segments, hit the tab key and the chain will be selected. (Beware of the Revit's spline - very hard to work with this one once completed)
Nachricht 4 von 4
constantin.stroescu
You can do almost everything you can do it in AutoCAD:
https://knowledge.autodesk.com/community/screencast/22352ab7-a9d6-4aa2-9f7f-94e442b72873
Editing a spline is also comparable.
https://knowledge.autodesk.com/community/screencast/3fb592a0-1d6a-48b5-8c3d-ba954c34834d
Constantin Stroescu
