Line Thickness
7 ANTWORTEN 7
Nachricht 1 von 8
jfjacques
773 Aufrufe, 7 Antworten
Line Thickness
I've gone in vg, object styles, override graphics in view - I can't seem to be able to change to the lineweight for these architectural columns other than by overriding the linestyle.
What's going on? Below is my view when coarse is on - it seems to change the lineweight.
and here these lines are w medium detail. Why would this change the thickness of the line?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: jfjacques
They look like Structural Columns.  In coarse, their line weight is governed by Stick Symbols subcategory under Structural Columns.
Nachricht 3 von 8
RDAOU
@jfjacques
Some families could contain imbedded/nested Detail Components with specific display settings...ie:
1. In coarse Plan view the 2D Detail component is displayed
2. In medium or Fine the 3D Element is displayed
In such case the weight of the nested component is under Detail Items and not Columns
Nachricht 4 von 8
jfjacques
als Antwort auf: RDAOU
Thanks that was it.
Nachricht 5 von 8
jfjacques
Though I can't seem to add new line styles in the family...
Nachricht 6 von 8
RDAOU
@jfjacques
You need to open the column family >>> select and edit the nested detail family and add the line style therein >>> then reload back to the column and subsequently to the project //// upload the column family I would gladly show you how...its a 30 sec thing
If the above solved it for you kindly mark the solution :leicht_lächelndes_Gesicht:
Nachricht 7 von 8
jfjacques
I'm in the family, where can I get access to the nested family? I can't access linestyles.
Nachricht 8 von 8
RDAOU
In the browser to the left under families... expand and select it.... Alternative is to hover over with the mouse and tab select the relevant element
