When I click the line styles and line weights dialogue, nothing happens. I can click line patterns and it's dialogue shows up, but nothing with the other 2.
Post a screenshot.
...or clarify what you mean. You can access line styles and line weights several ways in Revit.
I click this and nothing happens. I click "line weights" just below it and nothing happens. I click "line patterns" below that and a dialogue opens. It's just the first 2 that don't work.
If you click Line Type or Line Weight and you do not see the window but the Additional Settings dropdown menu disappears then the window is opening offscreen. Do you have another monitor?
I have 3 but it does not appear on any; I've removed them, so there is just 1, but still do not see anywhere...
Set Windows Display Scaling to 100%.
If that does work, reset Revit UI.
Neither of these solutions worked.
Then do a clean reinstallation of Revit.
@paulpurserY2QHY Here are more items to check:
