Line style equivalent line weight
mairh_tsek
mairh_tsek
Hello all,
Maybe a silly question but when we create a new line style, the line weight  (Projection) that I indicate in which scale corresponds?
Thank you in advance!
cbcarch
Manage Tab>Additional Settings>Line Weights
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Viveka_CD
Hi @mairh_tsek
See AKN articles:
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
mairh_tsek
@cbcarch , @Viveka_CD ,
Thank you for your answer.
My queston is that if I have in another programme a line with a weight 0.70mm and I want to create the same line in Revit when I go manage > additional settings > Line style > New, The line weight that I should give will be 5 (bec. in 1:50 it corresponds to 0.70mm or  4 bec in 1:10 it correspons to 0.70 too...etc  ?
d.avalishvili
manage>additional settings>line weights.
u can take f.e. line number 16 and edit line weights according to scale as u want 🙂
chrisplyler
If you want to avoid Revit's fancy schmancy ability to scale line weights according to view scale, then just decide that a 5 is 0.70 regardless, and assign 0.70 into number 5 for EVERY SCALE.
Viveka_CD
Hi @mairh_tsek
Thank you,
