Hi, When I draw a line of reference line they are slightly off axis, what should I do? Thanks
Try this -
Rina, It is not warning, the problem is the lines that I draw is off axis.
True. Revit is very intolerant of inaccuracies to a fraction of a degree. Which is why the link that I sent you recommends that you drag one end of the line away from its desired position and then drag it back to where it needs to be.
