Line shift when importing DWG to Revit
7 ANTWORTEN 7
Nachricht 1 von 8
565 Aufrufe, 7 Antworten
I have a DWg with simply 2 lines and 1 arc.
When I link this DWG into Revit, the vertical line is no longer 90° vertical.
Can anyone help me to solve this issue?
Beschriftungen (1)
7 ANTWORTEN 7
Nachricht 2 von 8
ennujozlagam
als Antwort auf: Anonymous
can you post the dwg files so we can check? thanks
Nachricht 3 von 8
RDAOU
@Anonymous
When you are on the Link CAD Dialog >>> Check the units ... Setting it to Auto is resulting in this deformation.  Either check in the DWG what units are used and set the correct ones or simply try using Meters or Feet and it should import/link fine
Nachricht 4 von 8
ennujozlagam
i tried no issues? set your VIEWRES to 20000  in autocad before linking. thanks
Nachricht 5 von 8
What's the point of this exercise? The DWG is puny. That arc is only 5/128" radius.  Revit is a BIM software - not a Circuit Board Design Software.
Nachricht 6 von 8
syman2000
Something is wrong with your arc. When I join it using PEDIT, it won't join the arc with the line. When delete the arc and use filet and set to 0.04mm, it join. When I link the CAD into Revit, it shows up fine.
Nachricht 7 von 8
als Antwort auf: ennujozlagam
VIEWRES is a good solution @ennujozlagam.  The only thing now to solve for is the Line Weight. I guess it won't be an issue if the OP keeps Thin Lines turned ON and doesn't Print.  Know what I mean?
Nachricht 8 von 8
als Antwort auf: syman2000
There's no issue with the DWG in Revit if you scale it up.
@100 Scale Factor:
w/Thin Lines OFF
w/Thin Lines ON:
DWG not scaled and linked into Revit as-is with Thin Lines turned OFF:
