Line Pattern: Dots
6 ANTWORTEN 6
Nachricht 1 von 7
XXalessio.amodioXX
2328 Aufrufe, 6 Antworten
Line Pattern: Dots
Hi all,
I want to create a dotted line as in autocad. Unfortunately dots appear as dash with smaller length.
Is it possible to create a line pattern with actual Dots?
6 ANTWORTEN 6
Nachricht 2 von 7
hugha
als Antwort auf: XXalessio.amodioXX
Revit imposes a minimum line length.   I believe that is  1/32".
hth,
Hugh Adamson.
Nachricht 3 von 7
XXalessio.amodioXX
als Antwort auf: hugha
That is a pity. There is no workaround in regard?
Nachricht 4 von 7
how big or small do the dots need to be?
Nachricht 5 von 7
XXalessio.amodioXX
als Antwort auf: ToanDN
Usually for structural overhead openings  we use a Dash Dot Dot line (Dash 0.7mm space0.6mm) I don't care so much of  dot dimensions. Just want to differentiate from the dashed line.
Nachricht 6 von 7
Make the dash longer then.
Nachricht 7 von 7
XXalessio.amodioXX
I use this solution for overhed structural beams and it works fine.
The issue occurs when I have to show overhead of structural openinng (e..g. door opening 800mm)
