How can lock icons in lines appear? I was modifying one line and suddenly it shows but I cannot control WHEN it goes out? I was trying to lock in place a line but i can't show the embedded lock icon to click. i would appreciate any explanation to this, thank you!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
@LanggamanXavierMassed wrote:How can lock icons in lines appear? I was modifying one line and suddenly it shows but I cannot control WHEN it goes out? I was trying to lock in place a line but i can't show the embedded lock icon to click. i would appreciate any explanation to this, thank you!
The Lock Icon is related to Alignment. If you perform an Align using the Align tool, the second element picked will move to align with the first element picked and then the Lock icon will appear.
If the element is already locked and padlock is missing when you select it, then the element to which it is locked to is likely not visible in the view. Activate Reveal Hidden Elements to see those hidden elements. Additionally, other constraints may be imposed on the element that you cannot see in the view. Activate Reveal Constraints to see those constraints.
