Line in 'in place mass' will only move on two axis. How do I fix this?
2 ANTWORTEN 2
Nachricht 1 von 3
harperrhett
1123 Aufrufe, 2 Antworten
I created a line on the bottom floor of my Revit project (indicated by the blue arrow), and then copied it to the third floor (indicated by the red arrow). I am trying to move the line outwards away from the building, but it only let's me move it up, down, left, and right. I'm new to Revit and I can't figure out why It's stuck to two axis. I thought It was a constraint or something but when I turned on 'reveal constraints' there was nothing.
FYI: I am in 'in-place mass' mode.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: harperrhett
Select the line and change the level on the options bar.
Nachricht 3 von 3
Because you draw the line when the workplane is a Level (by default). You can select the line and change its host to a different level or a named reference plane.
A better way is draw two points, create a line through points, then yoi can change the points Offset value to bring the the line up or down or even sloped.
Annotation 2019-03-07 105553.pngAnnotation 2019-03-07 105534.pngAnnotation 2019-03-07 105831.png
