Message 1 of 9
I'm experiencing an undesired graphic display issue with joined geometry and phase filters/phase graphic overrides. The attached examples show a structural beam and floor, joined together using join geometry. They are both of the same material. When the phase graphic override for cut patterns is set to "Solid Fill", a line appears between the two elements. When the override is removed, the line disappears as expected. Does anyone know of a way to have the phase filter override a cut pattern with solid fill and prevent the lines from appearing between joined geometry?
