Line based generic family won't schedule
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
Sahay_R
1763 Aufrufe, 8 Antworten
I have created this line based family to create a schedule for egress distances. For some reason it won't schedule. The schedule needs to show path and distance. When I create the schedule, I do not see the TRAVEL_DISTANCE parameter to add to the schedule. HELP!!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Sahay_R
The TRAVEL_DISTANCE must be a shared parameter.
Nachricht 3 von 9
Sahay_R
als Antwort auf: ToanDN
I thought it is shared! Isn't it? What went wrong?
Rina Sahay
Nachricht 4 von 9
Nachricht 5 von 9
Sahay_R
Family Parameter should not have been selected? When I select Shared Parameter it takes me to the company Shared Parameter txt. Idiot proof directions, please.
Rina Sahay
Nachricht 6 von 9
Well it tells youright there that Family parameters cannot appear on Tags or schedules.  Your project and your families must share the same Shared Parameters file.  Go back to your project and identify where the file is located, and choose the same file when adding parameters to the family.
Nachricht 7 von 9
Sahay_R
DONE!! Just stepped out of my comfort zone to do it!! ROFL!!
Rina Sahay
Nachricht 8 von 9
Sahay_R
Another question. How can I make this line follow the slope of a stair and document egress travel distances on stairs.
Rina Sahay
Nachricht 9 von 9
For that you will need to use an adaptive family so that you can pick the start and end points more freely.
