So I'm looking more into phasing but seems that I am limited in what i can do or being able to modify it. To start I need my walls to show different patterns/colors to show distinction, for the new and existing it's fine but when i need to identify if it's a low wall or overhead etc. Then I have the families I have, I need to show as new, existing or relocated (which it works great for)and since my families is really where my main focus is and where I will be pulling allot of my information from thinking I should just have the phasing for that and set up filters for my walls. Worried that if i get the patterns to show correct on the walls that the families will then have patterns as well which wouldn't be what I want.
Unless there is a better suggestion?????? I hope this makes some sense
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Phasing is the way to go.
Filters for Walls will be separate from filters for other families such as casework, equipment, etc.
So no need to worry about graphics getting messed up.
