Like instances not grouping in schedule
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
cbt990
313 Aufrufe, 5 Antworten
With itemize every instance checked:
without itemize checked:
obviously i am trying to show the total for each material
Revit is amazing
5 ANTWORTEN 5
Nachricht 2 von 6
cbt990
als Antwort auf: cbt990
Itemize does the trick with normal walls but for some reason it doesn't work with parts
Revit is amazing
Nachricht 3 von 6
Sort by Material?
Nachricht 4 von 6
cbt990
als Antwort auf: ToanDN
Almost worked, except i'm not getting sums for the Charcoal and Glacier White..
Revit is amazing
Nachricht 5 von 6
Format tab, set Area to Calculate Totals.
Nachricht 6 von 6
cbt990
Thank you!
Revit is amazing
