I am trying to get a plan where switches and lights are shown. I am using recessed lighting, that I cannot get to show up on reflected or any other plans. I have messed with the visibility graphics and view range and just cant figure it out. Any ideas as to what I can do?
Do other lights show? If not then it is either the light fixtures are unchecked in Visibility / Graphics (Keyboard shortcut VV) or the View Range is not reaching far enough in RCP (Can do unlimited view range if you are having issues figuring out what it should be, but that isn't recommended)
On a ceiling plan, make sure the view range goes up to or above the ceiling and the cut plan is below the switch height.
Can you see the ceiling? (apply a pattern to the ceiling, for swap in a grid ceiling to see it). Are light fixture and lighting device families visible? Are you switches and fixtures in the correct category and not some sort of generic family that may not be visible?
Use Ceiling Plan (not Floor Plan) and set Primary Range's Top to higher than the ceiling height.
