Lighting Fixture not producing light
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
1088 Aufrufe, 1 Antwort
Revit Version: Revit 2019 19.0.1.1
Windows Version: Windows 10 x64 1709
I made a custom light fixture based off of the Foscarini Aplomb pendant. I made it look good, and even made it so I could hang it from a sloped surface and remain vertical. However, I cannot get it to actual LIGHT anything.
It looks fine before I render. This is what happens when I render the view:
My settings are set to artificial only, and this is a closet I am using to test it. All of the other artificial lights render fine. Cloud rendering gave me no success as well.
I tried moving the source completely out of the light fixture, in case the "empty" part of my light was somehow acting solid and blocking the light, but it still did not render. I tried changing the shape of the light source, and the intensity.
Attached are screenshots settings for the family, and the light fixture. I cannot attach the family itself, unfortunately. Thank you!
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Nevermind, I fixed the problem. Still not sure what was wrong, but it started working after restarting my computer two times.
