light analysis does not generate
1 ANTWORT 1
Nachricht 1 von 2
207 Aufrufe, 1 Antwort
I'm experiencing difficulty when try to re-open and regenerate the light analysis that I have already done. The software keeps saying that the result is not available for this run and ask if I have logged in to the same account used to generate. I try restart both software and computer. I also tried to log out and re- log in but noting seems to work. What should I do to fix this problem?
1 ANTWORT 1
Nachricht 2 von 2
danieleaccardo
als Antwort auf: Anonymous
try to go to analyze-->insight-->lighting
A new window should appear in which you can choose if take a new analysis or select the old one. In this way you can update your file.
Daniele Accardo - Autodesk Student Expert
