Licensing System error 2
1 ANTWORT 1
Nachricht 1 von 2
520 Aufrufe, 1 Antwort
i have installed Autodesk Revit 2017 student version then when i tried to start it i got message tells that "licensing  System error 1" then i replaced it with Revit 2016 to get the same state but "licensing  System error 2" any one can help please!!? how may i be able to start it ?! thank you in advance!.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Did you check your internet connection ?
If my answer solved your problem , Please Kudo  and Accept as solution.
