License for VRAY for Revit
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
3686 Aufrufe, 9 Antworten
Every time I ‘m opening Revit the VRAY for Revit is asking me to insert again and again and again my license information.
I did the acquire license more than 10 times. That never happened with my previous versions.
What am I doing wrong? Thanks.
9 ANTWORTEN 9
Nachricht 2 von 10
aRcHiTeCt.JM
als Antwort auf: Anonymous
… hi @Anonymous
… you are not doing anything wrong
… after clicking the acquire license
… go to settings
… licensing
… check the obtain license on start up
... this way it will never ask you again for the license
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 3 von 10
I am not sure of whether we are talking about the same problem, my base product is 3ds Max not Revit. Here it goes, anyway.
I was using the wrong interface. The proper one is this:
http://localhost:30304
-Ramon
JFK Numbers
Nachricht 4 von 10
als Antwort auf: aRcHiTeCt.JM
Thanks again. I am learning Vray For Revit but so far it hasn’t been a piece of cake. I have lots of questions about it. Thanks .
Nachricht 5 von 10
Thanks. This was not the question but Thanks anyhow.
Nachricht 6 von 10
I hope that the folks that work in the Chaos Group "V-Ray for Revit" department are NOT reading this post.
Those in the "V-Ray for 3ds Max" department will be happy.
My project (Free Open Source 3D Model of Dealey Plaza) is by definition multi-platform, multi-application. I want ALL volunteers to feel welcome, whether they are from the Revit, 3ds Max, Blender, Cinema 4D, Maya, SketchUp, etc. religion.  : -)
If you want to deliver the most amazing and impressive renderings and videos, you should consider this route/workflow:
 Revit -> 3ds Max -> V-Ray
If you want to learn from seasoned experts, quick and cheap, consider this route:
https://www.freelancer.com
-Ramon
JFK Numbers
Nachricht 7 von 10
aRcHiTeCt.JM
… hi @Anonymous
… you can keep coming here to ask those anytime
… or even better yet …
… go to chaosgroup / v-ray for revit forums
… they will answer better … I guess
… and don’t forget
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 8 von 10
Of course. I forgot . Thanks.
Nachricht 9 von 10
Thanks. What do you mean? That the Vray for REvit is bad? Do you suggest to go through 3dsMax instead?
I've tried before with 3dsMax but was harder . The settings in Revit are apparently less complicated.
Please explain. Thanks.
Nachricht 10 von 10
V-Ray for Revit is not bad.
Keep in mind that I hire rented guns. I find
 - a LOT more
 - who produce the most amazing renderings
in the 3ds Max world.
-Ramon
JFK Numbers
