Hey,
I used bind link to bring another model into our file and now I have multiple levels which are on the same elevation.
Is there a way to fix this by somehow combining the levels? or moving elements to a differenc host level?
Thanks in advance!
if you aren't too far in the process, why not just go back to when you did the blind link, and uncheck the option for levels? guess not sure what will happen in this case, but worth a try i think.
you could reassociate walls to the level in your model, but from the looks of it this could take a long time.
out of curiosity, why did you even blind link this in the first place? not a very typical workflow
You can hide Link Levels through VGOs (Custom).
...also By Element and By Filter if Link is Custom.
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-EB571589-C335-4525-A8BE-CF1A2493B2F5
there is problem if you uncheck the levels and grid before bind the link ?
Thanks for everyone who suggested solutions! In the end we decided to keep the model seperated in two files and link them. the link binding ended up creating more issues providing value.
