Good morning. please see attached picture for your reference.
I want my Level 1, to become 00.00 (Not -14.00) as currently is, and of course, the full levels of project will also change Level 2 will be 3.50, level 3 will be 7.00. I don't want to do it one by one, it will create a mess, I guess. I want to do it in just one operation. Any suggestions please?
thank you
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Relocate your project in an elevation or section view and move it up 14 meters.
Sounds like you want to move the Project Base Point (or whatever the Level's Elevation Base is set to) in Elevation View.
good morning thank you for your response. how can I please turn on "base point?"
thanks
Go to VG, Site and expand Site. You can find it there (you may have to un-crop your view).
...or just Reveal Hidden Elements and you will see it in red. Select it and Unhide in View. Remember to UNCLIP it before you move it.
Thanks to everyone but my base point is gone gone gone gone, I open all my sections, create new ones, with all view templates, turn on site base point, filter, I tried everything, is gone gone gone
thanks
Thank you I said previously that my base point was gone, I found it EUREKA!!!
Thank you.
another question. how can I please set my 00.00 like 00.00 for my building AND show that my 00.00 is 2,538 meters above sea level shown on my topographic survey?
To accomplish this, create a new Level TYPE that uses the Survey Point for its "Elevation Base", place it on top of your existing Level 0'-0" and place the Survey Point 2538'-0" below this Level. The new Level will now read 2538'-0".
