Levels created but not displayed in Elevation view
REDO10
REDO10
Hi All,
I'm using Revit 2023, and I'm trying to create levels by dragging and copying the base level (Niveau 0). However, when I reach six levels, which are created normally, the next levels are created but not displayed in the Elevation view (I can't see them when they are being created or check their height value). However, I can see them in the 3D view and generate their floor and ceiling plans as shown in the image below.
How can I fix this issue?"
Thanks.
arq_42
Check the 3D extension of those levels, and the view clipping of that elevation.
Try generating a section from another site, to see if they appear
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
RDAOU
@REDO10
Check the extents of the view...
  1. It has a Scope Box applied to it
  2. Or it is Cropped
  3. Or Both
REDO10
@RDAOU
Effectively, the issue was due to the visibility limitation from the crop region, which I had not noticed.
Thanks.
