Levels are not visible to my Autodesk Revit 2025. Help me please
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
ID010285
323 Aufrufe, 5 Antworten
How to visible Levels in Autodesk Revit 2025. Not clickable
5 ANTWORTEN 5
Nachricht 2 von 6
constantin.stroescu
als Antwort auf: ID010285
you have to be in a Section or an Elevation View in order to make the command visible
Constantin Stroescu
Nachricht 3 von 6
vitorbortoncello
like constantin.stroescu mentioned, you can see the levels in sections or elevations and also checking them in VG in 3D view
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 4 von 6
ID010285
als Antwort auf: constantin.stroescu
Thank you I follow your instructions but didn't work. Still not showing in elevation view and section view and I'll check my visibility/graphics and check and still not showing the levels in Revit 2025
Nachricht 5 von 6
ID010285
als Antwort auf: vitorbortoncello
Nachricht 6 von 6
ID010285
