How to separate the names of the levels from the names of the floor plans
Gelöst! Gehe zur Lösung
Gelöst von vitorbortoncello. Gehe zur Lösung
Do you mean title on sheet
If you mean the name on level symbol, you need to edit a label in the anottation family, with name and elevation
Did you like the post? Accept it as a solution
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
